How's the vacuum switch work?
bike-maker
albany, OR
So I want to hook up an idiot light in my dash to my vaccum switch on the fuel filter housing. The truck is originally a gasser, so there is no wiring for it. How does the switch actually function? My assumption is that when it senses a vacuum, the electrical terminal just has continuity to ground. This sound correct? Makes for an easy hook up if that's the case.
jim x 3
1988 F-350 DRW
northern california
Bike,
The fuel filter pressure switch (on the filter housing) is a normally open switch that closes to ground (lighting the fuel filter indicator lamp) as a result of a clogged fuel filter. The fuel filter indicator lamp is supplied with +12V (hot in RUN or START) via 15A fuse 18. (From 1988 model year wiring diagram).
Regards,
William88
