How much is a 7.3 IDI worth?
Discussion in '6.9L IH & 7.3L IDI Diesels' started by BlueBreadTruck, Feb 21, 2010.
  1. BlueBreadTruck
    BlueBreadTruck IDI
    259
    Nov 19, 2009
    MA, cape cod
    I have the opportunity to buy a 7.3 IDI complete with about 120k miles. I am thinking of buying it for just the oil cooler, as I am out of options at this point.
    He is asking $400. How much do you think I could get for this engine after I take the oil cooler? Just looking to recoup my money i guess. Thanks
  2. Logroller
    Logroller Full Access Member
    113
    Dresden , Ohio
    wow 400 thats not bad if the motor still runs ,, here in ohio guys are giving 1000 to 2000 dollars for a good running idi ,, i have 3 7.3idi turbo motors that i wont come off of
  3. BlueBreadTruck
    BlueBreadTruck IDI
    259
    Nov 19, 2009
    MA, cape cod
    cool. I have no way to verify it runs, as its on an engine stand but was told it does. It does have a new Injector pump. it is N/a, serp belt with everything still attached,
  4. Logroller
    113
    Dresden , Ohio
    that helps ,,, when i bought all of mine i bought wrecked school buses that had the hd 7.3turbo and i paid 900 each for all 3 so if you put it on the net you might get more just depends on who is lookin and how bad someone needs one
  5. starmilt
    starmilt Full Access Member
    96
    Feb 13, 2010
    san jon n.m.
    Whats the story with the new pump and why is it on an engine stand.
  6. BlueBreadTruck
    BlueBreadTruck IDI
    259
    Nov 19, 2009
    MA, cape cod
    It was bought for the turbo, which is gone now. new pump? i dunno
  7. fury9
    fury9 Full Access Member
    699
    Oct 3, 2009
    island lake il
    dang, wrecked school busses? just the rebuilt pump you could sell all day for 145 buy it now
  8. DragRag
    DragRag Registered User
    2,031
    Aug 8, 2008
    Los Angeles, California
    $400 is a steal! better grab it before he comes to his senses, or someone else gets it, don't think, buy.....
  9. Logroller
    113
    Dresden , Ohio
    yeah thats true iv been offered 2500 for one of my 7.3 with a factory turbo on them
  10. icanfixall
    icanfixall Official GMM hand model
    24,892
    81
    If you go look at it see what the block serial numbers are. They are found on the drivers side of the block next to the injection pump gear cover. They will say 7.3T... Then some numbers... The true turbo blocks serial numbers start at 1,116,331 and go up from there. Anything below that is a non turbo block. Also all the oil port plugs are 1/4 inch instead of the 1/8 pipe plugs.
  11. Logroller
    113
    Dresden , Ohio
    i know all 3 of my motors are factory turbo i pulled them out of the buses myself , all with the 1/4 oil port plugs ,, and the feeds to the factory turbo 1/4 line which is a beautiful thing only expensive to replace at 80$ each to have them made
  12. BlueBreadTruck
    BlueBreadTruck IDI
    259
    Nov 19, 2009
    MA, cape cod
    ok cool! Thanks guys! He had bought the engine for his tow truck because it came with an ATS turbo....its the real old style with the wierd looking exhaust housing. I will be buying it for $350! Im gonna steal the oil cooler, and part out the rest. I will check to see if its a turbo block. are they worth more? It also comes with full acessories and a new starter!...it is a running engine!
  13. budget95
    budget95 Full Access Member
    130
    Jun 9, 2009
    Mass.
    I might be interested in the rest.
  14. hesutton
    hesutton The Anti-Anderson Supporting Member
    41
    7,714
    112
    Aug 19, 2005
    Bowling Green, KY
    Have have two 7.3's that I've bought over the last 5 years. Both were runners. One came with a good E4OD. I paid $200 a piece for the IDI's and $200 for the E4OD. :dunno Not a big market for them here I guess.
    Heath
  15. dyoung14
    dyoung14 Is getting worn out
    6,128
    Jan 2, 2009
    spencer,tn
    same here, i paid 150 for a running 6.9 complete, with a good working C-6
Share This Page
