How many First Gen. guys we have?
Ggg
Northern IL.
Does anybody know the diameter, length, and thread pitch for the two bolts that hold the vacuum pump on? 1990 D350 Cummins.
BTW thanks for the well wishes, I did walk away from the accident, just a little sore for a day or so. I will post pics when I figure out how to. I think the engine is ok, maybe I will be the first to do a Dode/PSD swap.........lol That will get a few people talking.
rayjon
Houston
I have a 92 regular cab 4x4 with a stick, POD injectors 16cm housing, 2 1/2 inch skyjaacker susp, and some 285 bfg's.... it will pulll 17k lbs at 70 mph no problem and goes like hell empty... next on the upgrade list is 4 inch exhaust and some more boost.... I can still run off and leave stock duramax's and powerstrokes in a 13 year old truck with over 250k miles on it..... not a bad rig all things considered..... I just wish it had bigger brakes and a heavier rearend...like the ford f550....
Up-n-Cummins
KY
I have a '91 D350 with a new Jasper Automatic in place and 250,000 miles ;Really
I use it for beatin' around, pulling goosenecks, hauling around my '96 pulling truck when I break it :D .
MUDDY
IDAHO
well,,,,,,,,,,,,,,,you can add my name to list of 1 genners,,,,,,,,again
92 d350 drw clubcab. just under 600,000 miles :) runs excellent
Mike
Stroker
Cora
Youre going backwards again mudster..........
bagged89
hey guys im a new member and i got a 89 first gen, its in the shop right now getting some custom body work done
MUDDY
IDAHO
bagged89,,,,,welcome to oilburners. i had an 89. good rig and the mpg was awesome. easy 24mpg w/ a 727 and was a 4wd.
lookin fwd to seein some pics of your 89
bagged89
i have some pics with the body in rough shape but no current ones as it is in the body shop. it is a 89 5speed 2wd and the body shop is putting on a custom 4 inch exhaust with quad 5 in tips and no muffler. I have my pump tweaked up and am waiting to get it back from the body shop to put on pyro and boost gages and injectors and smaller turbo housing.
Grey Wolf
Acton, Ca
Two in my family :D
Mine
[/IMG]
My sons '90
[/IMG]
William88
