Help with fuel filter housing upgrade
cutthroatxxx
OK so here's my issue.My 99 has a fass fuel pump totally different than the 97 so I can not use it for a reference. So the guy I bought my 97 from installed one of those Holley blue pumps I'd rather go back to Mechanical but that's not going to happen right now. My fuel filter housing seems to be leaking quite a bit for a little time now. So I want to go with different setup. I've seen those cat filters and similar looking ones. But I have no idea how do I hook one up what I have to pull out of the truck Etc.I don't know which one that I need that will work with my fuel pump Geno's garage as the 94 to 96 replacement fuel filter housing.So Idk if I should get one from Gino's what I should get if someone help me out and point me in the right direction I would really appreciate it. Thank you
cutthroatxxx
Basically, I want to eliminate the stock filter housing in go after market sure how to do it or which one to purchase or from where
Ah.
On my PSD i have the 4407 filter bases.
Currently have the 3367 and 33528 filters.
Which are a pre and post pump filter.
cutthroatxxx
I just can't figure out how in the hell I do away with the lines that go to the old filter housing & all that stuff
Been awhile since I've been around a dodge. It's not just a feed and return?
madmustang1965
