m67tang
I have a typ4 cam on my shelf of goodies
Now seems like a time to use it. My truck already has a turbo too.
I think that's the way it's headed.If you're going to do the cam at the same time, I'd recommend pulling the engine out. It's just SO much easier to do all of that work when it's on a stand. That way, you don't have to remove any extra from the truck either.
Is that boost limit on purpose? Do you have a waste gate turbo?I'm getting my place cleaned up to start on the engine work needed. Going to put the typ4 cam in too. Not sure if it's getting studs. I only run boost to about 7-8psi max. Going to take the heads and have them checked out and any work needed will get done too. Then freshen the fuel system with new IP and Injectors.
Hopefully after all that my truck will be ready for another 200k miles.
