Macrobb
Just so you know, you can definitely have a leaky hose clamp that only leaks under pressure. So it builds up as the truck warms up, leaks at that point and then stops.
So it's hard to trace unless you can see it.
Also, make sure that the overflow hose is in the overflow tank correctly and actually sucking/filling. If the hose was broken, that could cause some loss down to a certain point.
Not saying it isn't worse, but the easiest solutions should be checked first.
P.S, I really like the Zerex HD ELC coolant that I run in all my trucks. One of the 'interesting' things about it is that it leaves a distinctive pink/white residue on surfaces as it dries after leaking out. It makes it *really* easy to see where coolant is leaking, even just a little.
