1988 7.3 idi overheating on highway not idle. Will idle fine for 20 minutes plus but 10 minutes on the highway at 60mph and 2200 rpm will start to over heat please help. I'm on the side of the road
No after market gauge but it will be a the N on normal when idle and creep up when on the highway I pulled over and it was boiling over. And the hoses when over heating feel firm they have water flow through them
I do have v-belts I made sure there was no slip on the water pump I'm currently driving truck is running warmer than usual but with the AC off it's not overheating I'm still not sure of the issue I tested radiator cap overflow is working as it should nothing is plugged up but it is Running warmer-than-usual
I'm going to ask Calvin's question in a slightly different way. While over heating, would you say the hoses feel like an over inflated tire? Or under inflated tire?
