Yes very distinct smell indeed and burns your eyes
don't forget the basics.^
Is the oil pushing past the turbo seals? Seems like a lot of oil in the turbo to not be coming from the turbo.
Agreed and I was relieved to know but where is all that oil that collected in the CDR and pooling in the compressor side causing the turbo hat to be wet.
I think I am side tracked from the original issue the high amount of smoke the truck produce when I ran it around 2k RPM in the previously posted Video .. seems like unburned fuel !
Compression test pass
No sweet smell
Radiator pressure test loss about 1.5 PSi per hour
Next will be connect every thing back and wait for it to start smoke and start crack each injector and watch what happen
Something which you could do for peace of mind with all this, which has not been mentioned, is to get an oil sample off to Blackstone Labs. If you have any concerns about coolant or bearing problems, they will let you know what's going on. By everything that you have described, your pump and injectors are the place to start with your exhaust and running issues. That sweet smelling eye burning exhaust is always a sign of bad pump/injectors.
Any new purchase valley pan will have the better oil drain back already made into them. If the engine has the original factory valley pan it may not flow enough oil and back up.
