roamaround
Anybody know what the max temp on a getrag should be when towing?
I use a very good Schaffer synthetic oil. 20w 50. I run a long 20 mile hill at about 240 degrees 4th gear . I just switched to the recomended 10w30 weight and ran 275 deg while towing a different grade in 5th gear. Not sure if this is safe. Flat ground it runs about 200 while towing. I usually am towing around 20k lbs including the truck weight.
