derjackistweg
I need urged help. I have some electrical issues. And need a diagram or or...
Who can help me
PS my truck sits 200 miles away and I will go there tomorrow (GMT time). 1rst issue is IP install but than I would need to fix the electrical issues also, if in any way possible...
- Fuse with 30amps, upper half and vertical, is blowing every time I start the engine. Glow relay and plugs are new and working. They seem to run on this circuit. Also the electrical fuel pump (on the GP relay). What else could be the issue?
- Ignition switch seem to be false/ defect. I cannot kill the engine with it. Fss and IP are all fine (now). Can I test it? On which circuit is this running?
- Starter is not correct working. If I bridge the switch at the starter, the starter fires up. Not very sufficient I have a van and therefore no switch at the fender.
Who can help me
