fuel tank capacity for 1989 F250?
GREASE FIRE
Falmouth KY
i just bought my truck a few weeks ago and it did not have an owners manual, and i have no idea how much the two tanks hold. Can anyone tell me? My guess is 15-20 gallons each but i would like to know for sure, and i would also like to know if they are both the same size.
thanks,
paul
Diesel JD
Gainesville, FL
on the 80-86 they are both 19 gallons even though shaped totally different. Not 100% sure on the 87-91s
suv7734
BC Canada
According to the 1988 manual (diesel supplement) the tank capacities are:
Standard- 20.0 US gallons
Auxiliary- 18.2 US gallons
What the guy said about 20 and 18 in his manual is probably correct. It most likely leaves 3 gallons in the bottom of the tank when the pickup starts sucking air. So that would jive with the 17 and 15 mentioned.
My 89 manual tells me my from tank is 19.7 and the rear tank is 18.2. If you run the tanks empty and find to fill them up only takes a small amount you probably have the broken suction heads. Thats when you run out of fuel when the gauge tells you there is 1/4 tank left.Sadly this is where the broken suction pickup is at in the tanks.
gandalf
Senior Member
CA &/or Maine
This isn't a direct answer to the question at hand, but it may be an indication, and it may be useful to some people. This is from an Owners Manual for the 1986 trucks.
Macrobb
North Idaho
I've gotten no more than 17.5 or so into a completely empty tank. And I also have dropped and emptied a tank before; with a proper pickup, you /might/ have 1/2 a gallon in there when it sucks air(on a flat road that is - go uphill and it'll suck air earlier).
Here's fill ups in my 94.
Anything over 20 gal is filling the front, then some in the rear tank.
# Date. Miles. Gallon MPG. $/GAL
64 12/5/16 217.00 17.372 12.49 2.159
63 11/4/16 255.00 19.000 13.42 2.000
62 11/3/16 396.00 33.000 12.00 2.000
61 11/3/16 273.70 18.000 15.21 2.000
60 10/24/16 197.50 14.979 13.18 2.199
59 10/3/16 243.90 17.171 14.20 1.989
58 9/10/16 211.00 16.547 12.75 1.929
57 9/3/16. 225.20 17.622 12.78 2.009
56 8/22/16 226.40 16.463 13.75 2.079
55 8/15/16 240.80 19.707 12.22 2.099
54 8/8/16 232.00 17.896 12.96 2.059
53 7/29/16 274.70 19.601 14.02 2.029
52 7/22/16 17.251
51 6/30/16 19.000
50 6/23/16 259.70 18.468 14.06 2.059
49 6/11/16 328.50 27.000 12.17 2.099
48 5/31/16 281.80 18.663 15.10 1.959
47 5/20/16 236.20 19.042 12.40 2.079
46 5/13/16 271.30 17.363 15.62 1.839
45 5/3/16 262.80 19.696 13.34 1.939
44 4/20/16 258.30 17.385 14.86 1.749
43 4/12/16 222.60 16.472 13.51 1.759
42 4/2/16 220.20 16.624 13.25 1.799
41 3/26/16 251.40 17.593 14.29 1.799
40 3/19/16 266.50 18.968 14.05 1.799
39 3/11/16 261.90 18.439 14.20 1.759
38 3/1/16 266.40 19.418 13.72 1.659
37 2/22/16 242.00 18.709 12.94 1.790
36 2/13/16 17.885
35 11/30/15 18.500
Ramtough01
