Fuel filter restriction gauge
Discussion in '6.9L IH & 7.3L IDI Diesels' started by ghunt, Nov 13, 2009.
  1. ghunt
    ghunt Full Access Member
    1,158
    Sep 14, 2008
    Morgantown, WV
    How do you add a fuel filter restriction gauge to a fuel filter head like we have, or to a regular auxiliary filter head? Does it just go on the filter inlet?
    Been thinking about adding an auxiliary 2-micron filter between the stock filter and IP, and I saw some filter restriction gauges on Ebay and thought, hey- I should put one of those on each filter head so I wouldn't end up unnecessarily changing filter.
  2. maddenji
    maddenji Registered User
    45
    Oct 31, 2009
    Burlington,MI
    Usually a filter dirty gauge is set up to monitor both sides of a filter. This is called Delta or differential pressure. When the diff pressure rises the filter is dirty.
    You can also monitor the pressure on the outlet. When the filter is new the outlet and inlet pressure can be almost equal. As the filter clogs, the outlet pressure will fall. You can decide when the filter is dirty enough to change.
    Jim
  3. ghunt
    1,158
    Sep 14, 2008
    Morgantown, WV
  4. dmaxjoe
    dmaxjoe Full Access Member
    191
    Oct 31, 2006
    Mount Morris, Michigan
    I haven't yet but I am planning on putting a fuel pressure gauge between filter and inj. pump. I would feel alot better knowing my pump is getting enough fuel.
  5. hesutton
    hesutton The Anti-Anderson Supporting Member
    41
    7,603
    13
    Aug 19, 2005
    Bowling Green, KY
    That's where mine is. I mounted the sender in the brass elbow leaving the filter head and going to the IP.
    [​IMG]
    [​IMG]
    My pressure has been a bit low lately, and I know I need to change the filter secondary to this.
    Heath
Share This Page
