Ford 460 Motor Mounts
Discussion in 'Gasoline Engines' started by RustyBolts, Dec 6, 2009.
  1. RustyBolts
    RustyBolts Full Access Member
    395
    Oct 7, 2009
    Ohio
    Is there anybody out there that has a set of Motor Mounts and Frame Stands for a 1980-1997 Ford with a 460, that they'd be willing to sell? I just got outbid on a complete set from eBay, so, I'm on the hunt again. Can anyone help me out here?
  2. sassyrel
    sassyrel Registered User
    64
    3,714
    Apr 27, 2005
    iowa
    the set i have--is for 67-79--frames changed after that--no??
  3. RustyBolts
    395
    Oct 7, 2009
    Ohio
    Yeah, the '80-'97 frames are vastly different.
  4. Diesel_brad
    Diesel_brad Dunce
    6,099
    Nov 8, 2008
    gilbert pa
    I would try a JY for the stands and L&L for the mounts
  5. RustyBolts
    395
    Oct 7, 2009
    Ohio
    Do WHAT?????:dunno
  6. Diesel_brad
    Diesel_brad Dunce
    6,099
    Nov 8, 2008
    gilbert pa
    JUNK YARD
  7. tknomaj
    tknomaj Registered User
    56
    595
    Sep 24, 2008
    Anaheim Ca.
    how much do you want to pay i have a set in the bottom of my tool box 460 mounts from 1993 ford f350
  8. RustyBolts
    395
    Oct 7, 2009
    Ohio
    PM sent
  9. MUDKICKR
    MUDKICKR Full Access Member
    38
    1,426
    Apr 15, 2007
    NITRO WV 25143
    i dont know what your factory engine is but when i converted an 85 f350 from a 351w to a 460 i used the factory 351w frame stands. i just bought a set of 92 f350 460 motor mounts and cut off one stud. the only differance between the small block and the big block motor stands is the small block has one stud and the 460 has 2.
  10. RustyBolts
    395
    Oct 7, 2009
    Ohio
    This truck originally hada 400 in it. They're totally different than a 351w arent they?
  11. sassyrel
    64
    3,714
    Apr 27, 2005
    iowa
    yup!!
  12. MUDKICKR
    38
    1,426
    Apr 15, 2007
    NITRO WV 25143
    if you have the engine out take a pic, but i think it will still work. i know the trans will bolt up to a 460.
  13. sassyrel
    64
    3,714
    Apr 27, 2005
    iowa
    which trans are you saying will bolt up?? 351w--or the 400
  14. MUDKICKR
    38
    1,426
    Apr 15, 2007
    NITRO WV 25143
    the 400. the 221/260/289/300/302/351w/351c all use the small block bell housing. the 351m/400m (not 351modified400) 429/460 all use the big block bellhousing. i have a 78 bronco c6 transmission (factory bolted to a 400) bolted to my 460. same bell housing.
    also there is no such thing as a 351modified400, its either a 351midland or a 400midland. (thats what i mean "not 351modified400")
  15. Diesel_brad
    Diesel_brad Dunce
    6,099
    Nov 8, 2008
    gilbert pa
    I have never heard the "M" motors refered to as midland motors. They were always refered to as modified
Share This Page
