Ok, so after putting my bypass filter on my truck I've been doing some reading online seeing if there are any better options for the base that I got for my bypass filter which was this baldwin one
PART NUMBER: OB1305
Descriptions : By-Pass Lube Filter Base
Use_With : B50, B164, BT341
Contains : Threaded Stud 5/8-18
O.D. : 4 1/4 (108.0)
Inlet : 1/8 In. NPT
Outlet : 1/8 In. NPT
Length : 2 3/4 (69.9)
I got the B164 filter for my base because it was the largest filter of the three that were listed with it. I really like it so far and can honestly say that I visibly see a difference in my oil on the dipstick after running it for 800 miles. I installed it on oil that had 1500 miles on it and didn't feel like dumping out 11 quarts of synthetic oil that was still new, but there is actually a hint of brown in my oil now.
My question is, are there any better filters micron rating that will fit my filter base? After digging around on google for a long long time I found two to three threads that confirm similar information from others calling baldwin and getting told that the B164 (and the other two filters) are rated at 2 micron nominal and 10-12 absolute depending on flow rate. Even with that, that's a lot better then what the PSD full flow regular filter I'm running is doing, but it would be nice to find one that fits my base that does say 5-7 microns absolute if possible. I just can't seem to find anything online that is compatible. That being said maybe there isn't one. It wouldn't be a nightmare if I leave it be with this filter until summer and switch the base if there is a bypass I find that filters down better as I mounted it in the engine bay by the AC low pressure port / where the factory jack was located. Just might have to get adapters for the 1/8 npt ends on the inlet and outlet of my hoses.
I would be nice if any of the 100+ hastings filters at my local Rural King had literally any specs listed online or anyone at the store had any idea what I meant when I asked them if I knew what they filtered to. One guy replied the engine. Thanks. I wasn't sure there. They have a good 12-15 bypass filters and 5 of them fit my base when I brought it in with me, but again pretty much useless.
I don't know why filter companies don't advertise better what their products actually filter to. It shouldn't be secret info, when that's literally the only reason someone is buying the product. I'm not getting it because it's orange and it looks pretty in my engine bay. Nothing looks pretty in there.
Also, has anyone ever installed the giant donaldson filter https://www.amazon.com/Donaldson-EL...=1482419218&sr=8-3&keywords=donaldson+elf7405 on a two wheel drive idi (signatures are gone on mobile for me, so 1990 F350 Crew Cab ZF), I had looked into getting one of those once but I don't see how it will being longer without bumping into some metal. It's 11.7 inches verses the 8.3 of our FL1995 filters.
Not trying to become a filtration nut and run my oil for 10k, just don't mind spending an extra 200 on my bypass system like I did and buying a more expensive filter if it genuinely will help the truck last. I know the common theory is all this filtration helps the oil last not the engine, but I don't totally buy into that. Cleaner oil the last 500 miles of a cycle of oil has to be better for the engine then soot filled gunk.
PART NUMBER: OB1305
Inlet : 1/8 In. NPT
