F-150 leaf springs
Optikalillushun
Coal Region, Pa
I have a broken overload leaf on my 93 F-150. Picked up a set of F-250 leafs thinkin the overloads were the same. WRONG, they are longer.
So i was wondering, would it be feaseable to just remove all the leafs from my pack(s) and use the 4 springs from the F-250? I figure ill get about 2" of lift, and i can remove the 4" block i have in it now so i can use the factory 2" block again.
I cant just swap the spring packs, the knucklehead at the junkyard cut the springs at the main leaf to get them out.
Dieselcrawler
Professional wrench holder
Staff member
Quakertown Pa
I am the other way. My main leaf is stock f250, rest of the pack is bronco. Twists up a little better than it did
thamojster
