madpogue
Do all the turn signals actually work? Do the brake lights work? Do the emergency flashers work?
Ok so.. obviously I completely forgot I posted this on here and I haven't received any notifications that everyone had posted on this thread. Thank you for all your input!!! I will change my bulbs tomorrow! And see if that does it. I will post updates!!! Thanks again to EVERYONE!!!
One update I have,
I've noticed when I push the throttle to the floor.. it will shift from 1.....2.....3,4.........................OD.
I hope that makes sense?
Solenoid maybe? Or clogged filter? Or should I just take it to a transmission shop lol
To both posters,
The TECA (transmission computer) passes a small current through the brake light circuit. If the filaments in the bulb short, it confuses the computer. I would replace the bulbs, snd make sure the 3rd brake light (if equipped) is working. Also, LED "bulbs" cause problems also...... Simplest thing first, replace the bulbs...... If that doesn't fix it... Then we can peruse other troubleshooting.
