E4OD Light on, stuck in 4th gear
ISPKI
Granby CT
Hey Folks. I have a 1994 F250 7.3idi n/a with the e4od and this damn transmission has been causing me all kinds of trouble.
A few weeks ago, while driving to work, the "OD OFF" light came on and wont turn off, it feels like its stuck in 4th gear and wont shift out of it. I can shift it into 1st, 2nd etc with the shifter just fine which is how I got it home. The tachometer stopped working as well.
I read that this is most commonly caused by the engine speed sensor, so, I got in touch with a local idi owner (has a 93 f350) who let me come by and swap that sensor to see if it was causing the issue. I swapped it out but no change, still cant shift when in drive.
Is there anything else that could be causing this? Anyway I can test to see if maybe a wire in the harness is broken, or something at the tachometer is broken? I plugged my obd1 scanner into it but it didnt read any codes.
I am waiting on an LUK clutch, flywheel, and hydraulics for my ZF5 swap which I was not looking to do for a few more months, but it doesnt look like I have much of a choice.
cpdenton
Truck needs paint.
Conway AR
You have Lost power to the Transmission control unit most likely.
Check fuse U and the TECA relay.
gandalf
Senior Member
CA &/or Maine
Okay, you tried the tach sensor on the IP gear housing? You actually switched it out with one from another truck, and there was no difference? That was the first and most obvious cause.
Next, how does the speedometer work? The sensor for the speedo is on the differential, high on the frontside, and will cause E4OD problems. If the speedometer is working well, don't mess with that sensor.
It seems to me there is another possibility. Strange as it may seem, I'm pretty sure the tail light will/can be problematic for the E4OD. So, check the tail lights, the brake lights, the turn signals, the 4 way flashers. You might need another person for this, sitting in the truck.
That's a definite maybe. But it's an easy fix if it is causing the problem.
ISPKI
Granby CT
Gandalf, yes, I swapped the engine rpm sensor on the IP gear housing with one from another truck and it did not fix my problem. Speedo works fine, all tail lights work fine.
Icanfixall, tach does not work at all, sits at 0, hence why I thought that sensor blew.
cpdenton
Truck needs paint.
Conway AR
Your tach signal goes through the TECA before it gets to the gauge. If the TECA has no power, your tach goes dead.
gandalf
Senior Member
CA &/or Maine
The tach must work properly in order for the E4OD to work properly. If the tach is not working then there is no RPM signal going to the transmission computer. Without that signal the E4OD computer cannot perform it's function, and puts the transmission into limp mode. Unfortunately I think you'll probably get into the more technical aspects now, where fewer of us will be able to advise you.
My only suggestion at this point would be to check the cabling connections to the transmission, where the cable attach to the transmission. You'll be looking for that connection on the passenger side, behind a shield.
ISPKI
Granby CT
Great, I will look into everything you guys have mentioned starting with the fuse and relay for the TECA. Are the relay terminals clearly marked so I can test the functionality of the relay?
ISPKI
Granby CT
So the fuse is not blown, although it is also the incorrect size according to the schematic that CPDenton posted. I have not had time to check the relay, too much work and 3 degree weather today. Pleasantly surprised that the truck actually fires up in near 0 degree weather.
cpdenton
Truck needs paint.
Conway AR
Stole this from another thread. GREAT info here.
Post #7 on this thread.
http://www.oilburners.net/threads/tach.79067/
never jump to conclusions.it costs money.
you lost power to the trans.this is why you lost 1st gear in the D position.the tach may also not work when one of the below fuses are blown.
check the I and the U locations here.
full
note the "pcm" relay.this is used for the e4od controller.if those fuses are ok,honk your horn (your testing the relay) and swap the horn relay there.the trans and the tach will work fine again once you replace either those 2 fuses or the relay.
to replace the relay latter,just grab one at the auto store and snap the mount tab off.;)
note:
if fuse U is blown,inspect the fuel bowl heater line and connector at the fuel filter!
if this shorts out,your trans has this issues.
listen:
the fuel heating element is not required.disconnect and cap off this wire.
both of my tucks have this circuit capped off to avoid the issue.
if you want the fuel heater that's ok.just do yourself a favor and run a devoted circuit for it.;)
full
haha.oh man i love having these albums with pics handy.this is so slick.
NOAH MATTEOLI
SANTA ROSA, CA
ISPKI
Granby CT
It is very dim, difficult to read without cupping my hands over it. I will swap the relay out today after work. I believe I have some spare relays in the glove box, not sure if any of them work but I will take the suggestions posted earlier and test them with the horn relay position.
ISPKI
Granby CT
Solved! TCM Relay was bad. Swapped in a spare and the OD light is off. Shes warming up now, going to go for a spin in a few to make sure.
Well that's great news. Now for some info on that relay... It receives power from the passenger side fender mounted solenoid. It then has a fusible link found behind the battery on that side. I too had issues like yours last year. I replaced everything including the tach. It worked till I really needed my truck. then it crapped out on me but drove it anyway. Did plenty of teca relay search and found it needed power.turns out it has several circuits. One is power on all the time. another is power on with key on. So I used my multi meter and found no power to the key on circiut.So made a jumper from the drivers side battery and had a tach signal finally. Drove fine. So started tracing the wires from the relay back to the solenoid. That is how I found where the wires got power. Someone long before me made 3 wire splice repairs behind the battery in about a 3 inch mess on the same fusible link. So went to a wrecking yard and cut out the fusible links and spliced them into my harness. Shrink tubing and RTV and electrical tape fixed that mess. Now I have several fuseable links waiting for a need. I had plenty of help here and from Utube. Electrical shorts are not my field of knowledge...
William88
