DANA 60 INNER AXLE SEAL
Discussion in '6.9L IH & 7.3L IDI Diesels' started by ADV, Feb 24, 2012.
  1. ADV
    ADV Full Access Member
    505
    Dec 9, 2011
    Wisconsin
    I am in the process of changing ball joints on my 1993 with a dana 60 straight axle and have a inner ale seal that I need to change. I have never worked on a differential before what do I need to know about pulling it apart. Or whats the easiest way of changing the seals.
    I have the axle shafts out and the cover off right now.
    Thanks in advance for the help this web sight is awesome!!!!
    JOHN
  2. Goofyexponent
    Goofyexponent Mentally Unstable..
    33
    4,567
    Jan 7, 2009
    Halifax / Nova Scotia
    Undo the bearing cap bolts and pry the carrier and ring gear out...drop the tie rod to make some extra room.
  3. alienturtle
    alienturtle Human
    1,484
    Oct 17, 2009
    Ripon, CA
    yup its a pain in the but. you have to drop the ring gear and carrier out then the seals pound out and in from the inside. What i did was get a LONG bar or stack extentions. You will pound the right side seal in going through the left side axle tube and the left side seal in going through the right side tube.
    If i remember right there are 2 different versions of the seal. One has a metal guide cone on it so when you go to slide the axle shaft in it slides up the ramp of the cone and into the seal. The other version which is most common is just a flat seal and you have to pivot the axle shaft to get it lined up and through the seal. BE VERY CAREFULL you dont force it and tear a seal. Its do able just lots of patience.
  4. Exekiel69
    Exekiel69 Registered User
    5,381
    Jul 6, 2005
    I use a 3' by 2" wooden dowel pin to pop them out.
  5. ADV
    505
    Dec 9, 2011
    Wisconsin
    if you have to pry the ring gear and carrier out how do you get it back in?
    Thanks for the help.
  6. Drew2010
    Drew2010 Full Access Member
    300
    Oct 22, 2010
    Fulton, IL
    get it set in even and evenly tighten the bearing cap bolts, it will draw it in, then you have to torque them.
  7. ADV
    505
    Dec 9, 2011
    Wisconsin
    do you know the torque the bolts should be at?
  8. typ4
    typ4 Supporting Member Supporting Member
    56
    8,159
    106
    Dec 24, 2005
    Newberg,OR
    75
  9. sle2115
    sle2115 NRA LIFE MEMBER Staff Member
    49
    7,147
    Dec 3, 2005
    Southeast Ohio
    They make a tool to push the seals in, I bought one when I did mine, worth the money IMO. I believe I got it off ebay. It looks like a large engine valve with a threaded shaft. Then it has a bushing that fits in the seal and you thread it to push the seal in.
    Like this! but I didn't pay that much for mine...didn't have time to look a lot, getting ready to head out of town.
  10. ADV
    505
    Dec 9, 2011
    Wisconsin
    Thanks for the help everyone. My cousin came over and gave me a hand he did this before on his 94 f350 and he has a case spreader that he built that made the carrier come out and go in great.
Share This Page
