Correct timing procedure for 89 7.3 injector pump
Discussion in '6.9L IH & 7.3L IDI Diesels' started by ny.wolcott, Oct 23, 2009.
  1. ny.wolcott
    ny.wolcott Registered User
    Oct 23, 2009
    worcester, ny
    I have an '89 Ford 7.3 diesel. I suspect the mechanic incorrectly timed the injector pump after removing and replacing it to correct and oil leak, as it's smoking black heavily and running weakly.
    What is the correct procedure to align the pump gear with the engine gear?
    Thanks.
  2. Agnem
    Agnem Using the Force! Staff Member Supporting Member
    54
    16,966
    46
    Welcome to the site. Sorry to see your first post is another one of the "my mechanic was incompetent" variety. You need Ziggsters write up.
  3. hesutton
    hesutton The Anti-Anderson Supporting Member
    41
    7,716
    112
    Aug 19, 2005
    Bowling Green, KY
    Wow. That's not good. There are timing marks on the IP gear and on the cam gear. The mark for the IP is a "Y" and you should make sure they are aligned if you think the gear has been installed out of time. There is also a "o" stamped on the cam gear and is it for the crank gear, not the IP gear. Just to summerize "Y" to "Y" for the IP to cam gear timing and "o" to "o" for cam to crank timing.
    Read Zigg's article to more info.
    Heath
  4. ny.wolcott
    Oct 23, 2009
    worcester, ny
    Thank you so much!
    Now I can talk intelligently with my mechanic and find out just what he did.
Share This Page
