1. jarhead
    jarhead comfortably numb
    89
    Dec 20, 2003
    CT.
    This stuff is not for the faint of heart, but if you dyno,race,pull sleds or just want to show your ass on the street Cenpeco makes two different race additives. Outlaw and Pullers additive.
    They don't like water, make sure your fuel is clean. The cetane is so high with extended use you injectors will clog.and at $60 a gallon its not cheap.
    Now the positive side, It will cut your smoke by 75%. And you will feel the boost in power. But like I said its not for everyone,use at your own risk.;burnout
  2. Geno
    Geno Full Access Member
    385
    Dec 16, 2003
    Noble Ok
    jar head
    what this stuf got in it NITRO
  3. jarhead
    89
    Dec 20, 2003
    CT.
    Geno, I don't know what its got in it. They did say because it had metalics in it it was not street legal. It should only be used in trucks that are overfueled. Its the only thing I have ever put in my tank, were the boost in performance was seen with way less smoke, and felt seat of the pants. 1 gallon treated 3 tankfuls.
  4. pullinfarmer95
    pullinfarmer95 Registered User
    30
    17
    Jan 31, 2005
    ohio
    Just picked up some of that at power show ohio. outlaw that is. and i will be trying it out in y truck probably sometime around the first of june at the first truck pull. ill be sure the let you know how it feels and acts. i am going to be running a fuel cell in the truck so i can treat 10 gallons at a time instead of a whole tank and that way i can run it only on the track and not on the street. i am running it in a 5.9 cummins with more than enough fuel camshafting and other stuff. also do you know whow it may react with some nitrous!??!?? and what did this stuff do to egt's??thanks
  5. ISurvivedNMU
    ISurvivedNMU Full Access Member
    3,416
    Nov 30, 2003
    Michigan
    Welcome Pullin! Take some pics of that! Thats someinteresting stuff! Let us know how it works!
  6. pullinfarmer95
    30
    17
    Jan 31, 2005
    ohio
    does anyone know what is in the outlaw fuel additive. how much will it raise the cetane rating ? will the raise in cetane rating if any cause fuel to ignite sooner acting like advanced timming. if so how much. we are already over 30 degrees advanced and need to go a little more with billet cam launching at 5000 rpm thanks
  7. Dieselmaster
    Dieselmaster Diesel addict
    47
    984
    Mar 22, 2004
    Lake Havasu - Arizona
    it definatly is popular among the pullers...
    Seems like all the big names are using their lubricants... Dirtslinger, BigRed, Iron Dragon...
    On the cold weather treatment they say it raises the cetane from 1-12 points... This would make me assume that the Outlaw formula is doing a little bit more.
Share This Page
