Can I Tee here for a gauge
BrianX128
Pittsburgh
So on my old 1990 300 straight six I'm adding some gauges just like I did in my idi. The oil pressure sender is at a pretty easy location that I'm gonna T in my mechanical with the factory.
My issue is there are two coolant temp sensors. From what I read there is one on the back passenger side of the block that I can't even find and from the diagram looks in an awful place which controls the in cab gauge or...
There's one right up at the front of the engine right by where the heater hoses go. The only thing is from what I read I believe this one controls the fan clutch or somehow has a function outside of running the gauge. I'm wondering if I were to T here as my aftermarket coolant temp gauge actually is electric and has a smaller probe if the stock switch for the fan would be effected since its in essence almost T'd itself.
It plugs in the middle threads of this picture.
But I don't want to cause it not to work either. There's never a good spot for this type of stuff.
