Dino1191
Hey guys.
I have a 1985 F-250 4x4 with a 6.9L and have screwed up royally.
I replaced my IP and started having a leake from the connection from the brass elbow on the IP to the return line.
Being stronger than smart, I cranked on the connection and broke the elbow. I cannot find an elbow anywhere so had a thought.
Because the fuel return is low pressure and ends up going to rubber hoses at the end of the return line anyway, I was thinking of getting a brass 5/16" NPT nipple to put into the IP and a 3/8" nipple to connect to the return line, then connect the two with a higher gauge rubber fuel line and clamp both ends.
Before doing this, I wanted to check with you guys to see if you think this would be a good alternative or get any other ideas you might have.
Please let me know.
Thanks a million.
Please let me know.
Thanks a million.
