brakes!
jacobbingham
Florida
i replaced everything on the rear and bled it and brake pedal goes to the floor. then i discovered a leak right under the driver door out of some module thing i dont know what it is to replace it but its got 4 metal lines that run to it 3 small 1 big and a bleeder on the front. does anyone know what this is???? please help trying to get truck back on the road!! thanks
rebel_horseman
Rt. Wing Extremist
West Florida Republic
I'm guessing a distribution block. The big line is probably supply and one line for each front caliper and one to the rear of the truck. But that's nothing but speculation. By the way, when messing around with brakes you can bypass the RWAL system by installing a couple of fittings. This makes a big difference in how the truck stops. Just food for thought.
