Boost pressure in 6.5l
Discussion in '6.5L Diesels' started by dieselburner94, Sep 22, 2009.
  1. dieselburner94
    dieselburner94 Registered User
    Jun 21, 2009
    MA
    Just a quick question, i was wondering how much boost a stock 6.5l TD can really handle, considering the 21.5:1 compression? Ive heard of heath diesels pushing 22psi of boost with stock pistons, but yet ive also heard of others not being able to handle more than 15psi or so, then breaking crankshafts or destroying pistons when pushed too hard. Just wondering if anyone has any thoughts or info. Ive had mine hitting 15psi with no trailer or weight, and i dont want to do any damage if it builds any more when pulling hard.
  2. nitrohogg
    nitrohogg nitro junkie
    71
    Nov 2, 2006
    outside chicago
    ran mine fer years with about 15-16 PSI max......then the head gasket on the pass front started sucking antifreeze into the cylinder, and then out the front of the head!!!
  3. nodd89
    nodd89 Registered User
    Apr 9, 2010
    bc
    is that turbo timed or stock? whats the stock output supose to be
  4. nitrohogg
    71
    Nov 2, 2006
    outside chicago
    talking to me? I had a homemade wastegate controller on mine, stock is right around 7 psi
  5. silverfoot
    silverfoot Full Access Member
    110
    Oct 18, 2009
    canada
    We feel that the boost can go that (15psi) high, if 3 conditions are met, install exhaust temp gauge, pre-turbo and stay below 1100'F, change head gaskets to at least .010'' over thickness ( compression ratio drop) and head studs. The other is buy a main bearing girdle to hold the bottom end together.
    Otherwise just buy a pyro guage and keep WOP boost below 10psi and you should not have problems.....:thumbsup:
    Have you re-flashed your computer ? Error messages ? Or are you mechanical IP ?
  6. mahatma171
    mahatma171 Registered User
    49
    Dec 9, 2009
    Pennsylvania
    You can run the stock pistons (as long as they are anodized top for best results) but you still gotta do something about the compression, either as silverfoot said by running thicker head gaskets, or by modifying the valve seats for lower compression. Otherwise, you are straight asking for trouble anywhere over 15 psi.
  7. nitrohogg
    71
    Nov 2, 2006
    outside chicago
    not trying to step on toe's but! you don't wanna change valve seat depth's! I'll dig up my book and post the info as soon as I can!
Share This Page
