[B]Injector seat cutter[/B]
nic55kel
Nic55kel
Oakbank, Manitoba, Canada
Can anyone confirm that the correct seat cutter is 17mm X 17mm square cut.
The snout of the injector measures 17mm so it seems like a no brainer.
But don't want to buy and find out I was wrong.
Thanks.
the cutter a hair larger than 17x17. that's for just in case if the hole for the copper washer is carboned up and the washer can't seat properly.
nic55kel
Nic55kel
Thanks.
I think the injector seat cutter sets with a 17 X 17 bit must be right then.
I don't have one to measure but it makes sense that it would be very slightly larger than the washer.
I will confirm after I try one.
William88
