mattplumber
So I took the bait, and bought some snake oil to try and see if I can revive my tired IDI. My problems are low compression, heavy oil consumption, blowby, and smoking. The truck runs well otherwise, just trying to see if I can buy some time before a re-build or Cummins swap. I've seen several guys have had good success with auto rx and had a couple of questions for you guys.
1. I bought 2 bottles of Auto Rx and 3 gallons of Ford Diesel Oil to do my cleaning cycle. Will the Ford oil work well, or do I need to get something different?
2. Im burning about 1-1.5 quarts of oil a week, so at that rate the Auto rx will be burned up as well since its mixed in the oil. Do I need to add additional auto rx periodically when topping up the oil, or just top it up with straight oil?
3.Realistically, does anyone think any results will be seen? Ive never driven another factory turbo IDI before other than mine, so I have nothing to compare my truck to in terms of how well it runs per-say. I'm just thinking if it runs as well as I "think" it does, then the rings might be the problem, and the rest of the engine can be saved hopefully. Ive read several reviews of Auto RX and ive seen alot of people say it works well on freeing stuck rings, anyone have good luck with that?
4. Lastly, the LAST thing Auto Rx is gonna advertise is potential side effects from using their products. Anyone know of any POSSIBLE side effects I should be on the lookout for?
Any and all input is appreciated fellas!
Matt
Matt
