Alcoa wheel center caps, lug nuts??
Discussion in '6.9L IH & 7.3L IDI Diesels' started by f-two-fiddy, Mar 25, 2006.
  1. f-two-fiddy
    f-two-fiddy Registered User
    53
    2,954
    Mar 22, 2004
    Duluth, Mn.
    So I've got a set of Alcoa's on the way and need to outfit them with center caps and lug nuts.
    Will the 4.7" tall centercaps fit over the rear hub? Or will I have to go with the 6"? I suppose I could git off my butt and take a wheel off to measure um?
    I've decided not to use the Alcoa lug nut system. I don't like the idea of plastic lugnut covers. Which always seem to disappear, if you have to change a tire on the side of the road. @ $2.50 ea. A semi blowing by @ 65 will cost a guy 20 bux.
    So Imna go with either Gorilla or McGard lug nuts. Do I need a duplex lugnut for aluminum wheels, or will a standard 60 degree lugnut suffice?
  2. hheynow
    hheynow the misanthrope
    6,083
    Mar 23, 2004
    SF Bay Area
  3. NapaBavarian
    NapaBavarian Dually driver 6.9
    38
    2,011
    Jun 18, 2005
    Napa CA
    Southwest wheel is where I got mine
  4. f-two-fiddy
    53
    2,954
    Mar 22, 2004
    Duluth, Mn.
    I'm ordering my centercaps from SW Wheel.
    They list 2 covers for our years. The 2167 is 5.87"-(6") and the 3167 is 4.7"
    Will the shorter cap fit over the rear hub?
Share This Page
