rustygold
First it's a pain to put in the up pipe if that can't split anymore plus I wrapped it with exhaust warp. The only thing I didn't warp was the exhaust manifold.
In 93 did ford start making turbo block and used them in both application?
I have a M engine code. I don't know where casting numbers are on the block.
But the reason I ask is I was told that NA has a 1/8 inch for oil pressure switch and turbos have a 1/4.
Well mines a 1/4. I know people will tap them out to a 1/4 for the turbo set up, and here's the kicker there was no mod got a turbo on this rig. Firewall no dens ect.
I pulled that transmission down so I can cut the ear off and fix the trans leak, well it's cut off but not with a saw or grinder.
So what would be the possibility that my engine is a turbo block?
Sent from my SAMSUNG-SM-G870A using Tapatalk
