EB Bronco over head. Used the head liner out of one to mark the hole. If any one close wants the headliner can have it. Pics in reverse order taken. The OH is just loosely positioned before self tappers were installed to attach the mounting plate to the roof bows.
Need to do some more research on the schematics. While powering with jumpers, OH came on once and shut down. Electronic mirror continues to work with out issue. I have a total of 8 wires:
White/purple stripe: switched 12v fuse protected
Black: ground
Green/yellow stripe: courtesy lamps
Black/blue stripe: ^ same
Light blue/red stripe: speedo back lighting
Dark blue/yellow stripe: sensor
Black/pink stripe: key in ignition noise maker circuit
Grey/black stripe: ties into speedo/PCM/ cruise. Unsure of what kind of signal this is. At the CC module says speed in yet the speedo says vss self test circuit.
