7.3 IDI turbo cold starting problem
jdphish
Mississippi
Thanks to all and pappy19 it does have a block heater and I located the plug. It was in front of passenger side battery. We are supposed to get low 20 degree F temps this weekend. Should be a good test. Thank you!
Hydro-idi
Lodi, California
You should not need a block heater at 20 degrees F. Yes, it is much easier on the engine if you use one in the winter, but something else is going on with your truck if you need a block heater at that temperature.
jdphish
Mississippi
Hydro idi, may not need one. Just had that one incident so far. Its precautionary at this point. Just because its a 23 year old truck.
jdphish
Mississippi
19 degrees yesterday morning, block heater plugged in, cranked right up. :)
Thanks for all the help from each of you!
Jd
