UPDATE:
I "fixed" the leak at the fuel heater terminal (I just copied what, Stang65fst, did and JB Welded a plug into it).
Yesterday I tried bleeding the IP again, this time two different ways: First, with everything hooked up but I left 4 IP lines off (the top 4, that are easiest to reach). I saw nothing at the outlets.
I then plugged off the fuel return line at the filter. I read that this is common practice anyway, and sense I was getting a lot of fuel from that line, I figured maybe plugging it off would increase the pressure on the IP enough to get it primed.
I was (am) also getting fuel coming out of the return line were the IP bleed line plugs into. (It's leaking at the plastic part where it sits above the injector - not coming out of the top like they say would happen if the injector was getting fuel) So, by running a line from the top of the IP into a bottle, I wouldn't have the leak I had before... Now, with the Filter Bleed line and the IP bleed line taken car of, I tried priming the IP. Still, I have those 4 IP lines opened at the IP.
Still nothing coming out of the IP. I have a steady stream of fuel going to the bottle from the IP bleeder. No air.
I was told by a "guy I know" to spray ether into the motor until it starts and than spray it every few seconds... this will pull the air out of the "locked" IP. I told him thanks, but have read on this forum that its not healthy for the idi.
I'm running out of combinations of how to start this thing.
I wonder: i can hear the valve on the IP clicking when i apply power to it, but the engine harness I'm using is off an Automatic truck. Could there be some other reason the IP wont flow? I did us a "jumper" on the clutch neutral switch that I pulled off a manual truck. I understand that that is all it takes to "trick" the truck.
((I'm using a 93 motor out of a manual, in 92 frame and using that same 92's engine harness - which was an automatic before the PO did a manual swap - and the cab is off a FUEL INJECTED 1994 f250 manual))
I will pull the bleeder valve and see if its obstructed, I guess - but because i'm getting plenty of fuel, I'm sure its fine.
Thanks for the feedback, thus far, and any help is very appreciated. ((sorry to drop the fuel injected part on everyone - it never really dawned on me that it could be relevant))
