6.7 cummins catalysts
Randal Brown
Edson, Alberta
Does anyone know how to eliminate the catalytic converters off the 6.7 cummins? Everything I've been searching shows a hook up to the stock filters, is there a bypass to get around having the filters on at all?:dunno
mprmn08
Michigan
hs performance has a delete kit and theres also another company but i cant remember the name. if you go to yahoo or google and type in dpf delete kit then some should pop up and that will bolt up to your down pipe and get rid of all that ****. it gains about 2-4 mpg's doing that also.
