6.0l driving me up a wall please help
rustygold
conway Arkansas
Well clean it out got some debris screen looked ok but replaced it anyway.
Still no start
New development ficm no voltage/ no sync to computer.
Icp 1500 matches desired psi
Irp 42%
So I'm going to check wire harness make sure I don't have an open the if it's good pcm change
Sent from my SAMSUNG-SM-G870A using Tapatalk
Dsl_Dog_Treat
Decatur,MI
Make sure Ficm Harness connectors are all snap locked in firmly and ground wire attached to manifold stud. Sounds like the main FICM harness isn't totally connected.
rustygold
conway Arkansas
It is got to looking some on the pins was backed down in there a little bit I'm thinking the ficm had an intermediate problem from connection. Wire get hot looses voltage.
Now my only thing I couldn't find do a 7 pin ficm computer be swapped to a 4 pin ficm.
I know the boards are not but what about the whole system
Dsl_Dog_Treat
Decatur,MI
All of the replacement FICM's are 4 pin. But if you've replaced yours, the PCM needs to be flashed to sync with the FICM.
rustygold
conway Arkansas
She's alive she's alive idle at a good 800 to 900 at 25%
I have to scanner on it recorded so if it shuts down I can see what drop out first
rustygold
conway Arkansas
Now at operating temperature
Icp 630 matching desired
Irp 25%
rustygold
conway Arkansas
Lost FICM synchronization
Icp was 630 psi down to 25 psi
Irp 25% to 40% to try to kep it running I'm think the synchronization drop and shut down injectors
rustygold
conway Arkansas
P0603 code is showing up now
rustygold
conway Arkansas
Nope plain Jane I'm going to pop the ficm relay if no sync the going to cam and crank sensor
Dsl_Dog_Treat
Decatur,MI
OK good deal.
Ipr duty cycle is just about twice as high as what it should be at operating temp idle, but I think we need focus on why the PCM popped a 0603 while it was running.
