460 gas mileage vs 5.4
Discussion in 'Gasoline Engines' started by superduty12v, Feb 13, 2011.
  1. superduty12v
    superduty12v Full Access Member
    276
    Oct 28, 2010
    CT
    im goin to the dark side and gettin a gasser. this sucks. cause my mileage is going down from my cummins, but havin a truck i can do a diesel swap in next year is worth it in my eyes. but what gas mileage, unloaded, then towing about 10k a few times can i expect with the 460, vs the 5.4. if i grab that 460 im gonna do a swap, the 5.4, im not sure.
  2. benton
    benton Country boy
    385
    Jul 31, 2008
    Bushkill Pa
    i get about 8 to 10 with my 460 just normal driving. it loaded down with fire wood i get about 6mpg which is very bad lol. my neigbor has a 07 or 08 f250 with the 5.4 and gets about 15 he says unloaded and when he pulls his new holland tractor behind it he gets about 8. hope this helps you
  3. superduty12v
    276
    Oct 28, 2010
    CT
    the guy i talked to said with the plow around town it was 10 and about 12 highway. our overloaded e150 van isnt much better with the 5.4. ill keep it for a year or so then throw the IDI or 12v cummins in there. btw i like your sig. you may be a redneck if you spent more on your truck than education. thats how its gotta go;Sweet:rotflmao
  4. superduty12v
    276
    Oct 28, 2010
    CT
    whatre some mods i can do so i dont have a stroke at the pump. lol its a 95 or 97 idk, but im thinkin high flow air filter and a straight pipe. any tuners?
  5. benton
    benton Country boy
    385
    Jul 31, 2008
    Bushkill Pa
    thanks thats how it is with both of my trucks cant you tell by my lack of spellin skills :rotflmao .:dunno i dont know of any mods that you can do to save gas just make more power and burn more. all i can say is try not to hot rod around all the time or youll watch the gas gauge go down as your tach needle goes up lol. if i was you i would just stick with the diesel. ill fill my 460 powered f350 up on monday and usaully have to fill it thursday night maybe friday and i have a 19 gallon tank and with regualer gas its about $50 to fill it and it dont last long. it may cost more but i can fill my 92 idi and have it last till the next monday if not longer it just depends on how i feel like drivin it that day
  6. rjjp
    rjjp Needs to go test
    27
    1,764
    Dec 16, 2009
    Clare, Mi
    Used to have an 88 F-SuperDuty with the 460, got 16mpg.
    Used to have a 97 F150 with the 5.4, It could get 18 on the freeway, as soon as it smelled a stop sign or light it dropped to 15-16.
    Currently have an 05 F250 with the 5.4 (my fathers truck) 12-12.5 empty or loaded, in the woods in 4 low or on the freeway with the hubs unlocked. Speed doesn't seem to affect it either, burn a tank going 60-65 then the next tank got below 80mph for 10 miles. Still the same fuel economy.
  7. superduty12v
    276
    Oct 28, 2010
    CT
    huh. well idk what im gonna do yet. i cant realy stick with the diesel because she needs bodywork and i dont have the money to do it. the 460 is in better shape and by this time next year i should have all the $ saved plus. to do my diesel swap. so i figure i can go that route. either with the 5.4 or the 7.5 460. i dont know yet. either way ill be pullin about 2500 lbs of landscape stuff around with a toolbox in the back. ill lean toward the 460 for now. the mileage is about the same. but a little extra go fast wont hurt
  8. MUDKICKR
    MUDKICKR Full Access Member
    38
    1,426
    Apr 15, 2007
    NITRO WV 25143
    if your planning an engine swap down the road get the truck with the 460. the trk with the 5.4 is going to have a lot more electrical to deal with in the swap.
  9. Diesel_brad
    Diesel_brad Dunce
    6,099
    Nov 8, 2008
    gilbert pa
    Come on? really? quit F'n w the guy.
    a 460 will get between 6-15mpg
    My crewcab 460 5spd 3:55 gear truck doing a 500 mile highway trip from NJ to VA w the cruise set at 65 w 33" tires got an all time high of..........13mpg
    There is no way in hell a 8k F-superduty w dual wheels and 4:88 or 5:13 gears would get 16, unless it was in neutral getting pulled
  10. rjjp
    27
    1,764
    Dec 16, 2009
    Clare, Mi
    13,000lbs, 4.63, gutted cat with dual cherry bombs running an between 70 and 75 in OD (5th) with a wide ratio ZF5. But it was a fresh engine (had 51,600 on it when retired)
  11. superduty12v
    276
    Oct 28, 2010
    CT
    haha. im expectin 13 mpg. either truck. my dads advising against the big block. and the bb chevy another guy wanted to trade but idk diesel swap is where im going.
  12. 94f450sd
    94f450sd Supporting Member Supporting Member
    38
    6,518
    Oct 12, 2005
    somewhere,ma
    id hate to see the fuel mileage from a 460 with 5.13 gears :eek: with 4.10s a 460 will pass everything but a fuel station.oh and i love a 460!!:love:
  13. 94f450sd
    38
    6,518
    Oct 12, 2005
    somewhere,ma
    still callin BS.a 460 with 4.10s is around 3500RPM at 60MPH.my first f350 car carrier was a 460,5 speed,4.10s and i was pushing it well past its comfort zone at 65MPH.runnin 70 with 4.63s would kill a 460 quick.no Fin way you got 16MPG out of a 460.my 88 f350 crew cab dually EFI 460,5 speed and 4.10s was gettin a max of around 10-11 MPG
  14. Clydesdale
    Clydesdale Full Access Member
    1,155
    Nov 8, 2008
    Nampa,Id
    8-10 out of my C 350 with a 460, at 15,200# or at 6,000#. E40D, or NP435.
    10 out of the 98 Expedition 5.4 towing a 20' 1972 Kit Prowler, 14 ish running 75 Bpoise to SLC.
    12 as a drivearound truck on the Expy
    Have a friend, two 460's. 89 ZF5 C 350, 4.10's 35" ires, 17 mpg highway, 12~ in town. 94 C 350 ZF5 3.54's 12 empty, 10 towing. use to do 14/12. Same truck with a PSD 75hp over, E40D, 35"-40" tires (had a superlift electronic re-calibration goodie hard wired), 14-16, 4.10 gears.
  15. rjjp
    27
    1,764
    Dec 16, 2009
    Clare, Mi
    You wanna check your math?
    3500/.76=4605.26316
    4605.2316/4.10=1123.23492
    11.23.23492x100.53=112918.80651
    112918.80651/12=9409.90054
    9409.90054/5280=1.78218
    1.78218x60=106.9308
    So a ZF5 equipped 460 running 3500rpm and a 32" tire, in 5th is going 106.9 miles per hour, not 60, with 4.10 and in OD it's going to be turning roughly 2000 at 60, just like an IDI.
    Now lets figure out what the 460 runnin the ZF5 and 4.63 is turning at 75
    75/60=1.25
    1.25x5280=6600
    6600x12=79200
    79200/100.53=787.82453
    787.82453x4.63=3647.62757
    3647.62757x.76=2772.19695
    Well within the comfort zone for a gas engine that will scream past 5000
    Hell my IDI has run that kind of RPM for over an hour straight that I know of.
    If you are running a 32" tire and a ZF5 (in 5th) turning 3500rpm at 60mph that would mean you had 7.30 gears.
    SuperDuty12v: I apologize to you for the hijack.
Share This Page
