if someone could bring a meter that would be great. I would like to check the timing on my engine.
Cory brought his last year.
I'll toss mine in if someone reminds me.
Hopefully I'll have figured out how to use it by then.
when you look under the truck's butt, if there is a cover, it' a 110. if you are greated with a rear that looks like a old ford 9in but ate the jar of miracle grow, it's a 135I'll have to crawl under it and see what axle they are using now. Supposed to be heavier than previous. Who knows. I'll see what is stamped on the axle.
The 4.30 gearing is pretty low, but I plan on using it.
I have 100,000 miles/6 years on the engine warranty. The only thing I'm doing under the hood until then is routine maintenance.
Heath
Good deal man. Mel did a formal timing clinic for years at these events. He would literally time trucks for hours in the boiling hot sun under boiling hot truck hoods. God bless him for that. He sacrificed a full day of his vacation year in and out to help fellas have a properly timed rig.I have a Kent Moore timing meter that will be in attendance.
Well Calvin, I'm confused now. Is Ford making the rear for the F450's? The diff cover has FoMoCo stamped on it. No Dana markings that I can find on the axle. I've looked for axle model information on the 2017's, but found jack squat so far.when you look under the truck's butt, if there is a cover, it' a 110. if you are greated with a rear that looks like a old ford 9in but ate the jar of miracle grow, it's a 135
you know what to do. when in doubt, post a pic.Well Calvin, I'm confused now. Is Ford making the rear for the F450's? The diff cover has FoMoCo stamped on it. No Dana markings that I can find on the axle. I've looked for axle model information on the 2017's, but found jack squat so far.
The front is a Dana. Looks like every 60 I've seen before.
Heath
