2003 6.0 running rough, no power, white smoke etc...
Diesel1050
Minot Maine
Well i'm getting pretty annoyed with this. Have a 2003 F-350 6.0, that over the past week has been running worse and worse, to the point where it is barely driveable. Did oil change done recently with 2 bottles of Rev-X, just changed fuel filters, truck has 126k on it. Recently had the ICP go, so I cut the wire to it and it stopped the stalling/rough idle issue. Fast foward a month, and it suddenly blows a bit of white smoke at startup (Definitely from diesel, not coolant/water), and has NO power, NO turbo etc. Thing barely shifts (Have to let off for it to shift). FICM reads 48.5v at idle, EGR is good (Pulled it and cleaned w/new O rings. At this point i'm thinking bad fuel injector (s). Any thoughts? Also it seems since i've owned it the turbo really hasn't functioned properly. Doesn't act like an '03 turbo should....
<br />
<br />
Sent from my SM-G930R4 using Tapatalk
rustygold
conway Arkansas
Sounds like injector failure. Need to know icp readings and pull a power balance test.
Sent from my SAMSUNG-SM-G870A using Tapatalk
rustygold
conway Arkansas
But if I was you if you pull one from one bank pull the all.
boxathey
meadville,pa
I would also check your MAP sensor located on passenger firewall small hose going from it to the passenger side of the intake manifold. I've seen holes in the hose and/or hose not seated correctly giving false pressure readings causing severe lack of power. I would definitely do a contribution test though. Any codes apear when you scan it ?
William88
