2001 International T444E
Discussion in 'General Discussion' started by spg, May 3, 2005.
  1. spg
    spg Big Red
    302
    May 3, 2005
    Columbus, OH
    Looking for information on how to add more HP to a 2001 International T444E 175HP
  2. RKOCH
    RKOCH Fellow Oil Burner
    563
    Feb 21, 2005
    Yorktown, Virginia
    Most everything for a ford will work fine just go to the banks site and shop.
  3. spg
    spg Big Red
    302
    May 3, 2005
    Columbus, OH
    The motor is the same but all the electronics are different.
  4. RKOCH
    563
    Feb 21, 2005
    Yorktown, Virginia
    Not as much as you think we put all kinds of banks shit on them. Six gun tunners ,big hoss modules, high boost comp wheel, exhaust brake and a big head wastegate actuator and the things run their ass off.
  5. Duke
    Duke Full Access Member
    804
    Jan 22, 2005
    PA
    You can do the 10K mod to it for about $5 bucks and pick up some pretty noticeable torque. You can do it yourself in about 2 hours. ;Sweet
  6. spg
    spg Big Red
    302
    May 3, 2005
    Columbus, OH
    I am aware of the 10K Mod. I am looking for additional things to help with the power. The newer IH T444E motors are different than the older in the Electonics parts and the Banks and most other pieces for the Ford application will not work on them. Seems like someone somewhere has run into this besides me.
  7. Duke
    804
    Jan 22, 2005
    PA
    I'm sure NeverenufHP will be reading this soon. he can help, too.
    BTW WELCOME TO THE SITE!!!!! ;Sweet
    We look forward to your participation & letting us know how you make out with your T444E!!!
  8. RKOCH
    563
    Feb 21, 2005
    Yorktown, Virginia
    We used a ford ECM because NAV pak will not commicate with the banks stuff.
  9. nevrenufhp
    nevrenufhp torque junkie
    45
    423
    Feb 5, 2005
    Modesto, CA
    I think Hypermax makes the Maxchip for the T444e. The other option is to swap to the Ford ECM and use your choice of performance module. Then you can add the fuel pressure regulator shim, and the 10k or diode(clamp) mod. Then....if that's still not enuf, you can call Diesel Innovations to order a set of custom hybred injectors :Sly , but then you'd need a lot more air. It's a vicious cycle! :D
  10. spg
    spg Big Red
    302
    May 3, 2005
    Columbus, OH
    Changing the ECM is not an option because truck has cruise and all electronic dash. Which would not work with changing to Ford Electronics. I was hoping to find out if there is a way to reprogram or replace the IH electronics. They offer this motor up to 250HP. I imagine most of the difference is in the computer.
  11. dozer
    dozer Full Access Member
    117
    Mar 31, 2005
    sw Oregon
    well....I would imagine it's more than just the ECM. Check the part #'s that are in it now, but I'm thinking you'll probably have to swap the injectors out to make it a 250HP version.
Share This Page
