1st Gen Power Steering pump on 97 24v
Discussion in '1st Generation Cummins' started by Waystro, May 10, 2015.
  1. Waystro
    Waystro No Class
    20
    2,502
    May 11, 2014
    South Texas
    Will a 1st gen power steering pump work with a 24v?
    Don't know if the 1st gens had HydroBoost.
  2. The Warden
    The Warden MiB Impersonator Supporting Member
    36
    7,337
    Fog Bless Pacifica (CA)
    I think the 1st Gen trucks had vacuum brakes...I know my friend's old '91 W-250 had a vacuum booster.
    Note the vacuum booster in the upper right of the picture ;Sweet
    I think '97 would still be 12 valve; IIRC they switched to the 24 valve midway through '98.
    I'm not sure if the power steering pump will work, but I imagine it would, although you may have to get creative with the hydroboost return line...
  3. Waystro
    Waystro No Class
    20
    2,502
    May 11, 2014
    South Texas
    Thanks I was going to give mine to a friend. But he'll be better off buying a new one.
    It's got a 24v swapped in.
  4. gonecrazyi
    gonecrazyi Full Access Member
    26
    3,259
    Aug 27, 2008
    florida
    You can swap the cans on the back of the pumps
  5. The Warden
    36
    7,337
    Is there a two-return-port can that'll go onto a PS pump on a first-gen 6BT?
  6. F350camper
    F350camper BOOST!
    1,551
    109
    Jan 11, 2005
    Northern, VA
Share This Page
