I'd say so man. You don't have anything else in front of the radiator that carries oil.
Heath
Heath
Are you sure it's not antifreeze weeping from the plastic tank seam? It gets sticky too when you boil off all the water but it would probably wash off fairly easy.I pulled the radiator out and noticed some oily spots on the fins that have collected dirt. could this be from the condenser weeping oil? I replaced it a few years ago but maybe I need a better one. any other ideas?
You must be registered for see images attachYou must be registered for see images attachYou must be registered for see images attach
