Everyone should read this.
http://beru.federalmogul.com/sites/..._all_about_glow_plug_pfmbu1435_-_en_lores.pdf
1: Antechamber, they're usually called Precombustion chambers or "Precups" around here. Also, these engines are called IDI's because they're In-Direct InjectionAfter reading the document in the original post, I would like to ask, for my (non-turbo) 1988 F-250's 7.3 IDI diesel:
1. Is this a AnteChamber, Turbulence Chamber or Direct Injection engine?
2. A number of different types of glow plugs are described. What type(s) does my engine take?
3. Will it take these "BERU" type glow plugs?
And then on another note:
4. I noticed that in recent cold weather it took several tries to get my engine started. On this occasion the weather had been below freezing for an extended period but the morning sun had warmed the engine compartment while the temperature of the engine itself would have still been below freezing.
This curious/unusual difficulty in starting the engine that day made me think that the sensor that determines how long the glow plugs operate before the wait to start engine light goes out must be on the outside of the engine where the engine compartment temperature was significantly warmer than the engine temperature itself perhaps causing the glow plugs to "turn off" prematurely. Is that possible?
Thanks for considering my newbie questions.
4: The GP controller uses a coolant temperature sensor towards the front of the engine to help determine how long to glow the plugs, but if the sensor is bad I don't know how the GP controller would act. Someone who knows what they're doing will probably chime in on this.
Absolutely no issues with mine. On a warm day I have no need for GP's.The only advice I can give, your idi diesel pickup is not going to fire off like a fuel injected gas engine. It's not even going to fire off like a carbed gas engine. These diesels are harder to start than other engines. Some diesels fire right off, some don't. I don't care how warm it is outside, these idi's always like some glowplug time before they start. .
