That blue sea stuff is nice.
Finished off my battery cable upgrade with a new auxiliary fuse panel for my accessories. It's attached to the factory fuse panel cover with some HD velcro, and there's enough slack in the wires to easily move it out of the way to access the factory fuses.
Currently have the rear axles out to replace wheel bearings & do a diff oil change. Unfortunately the parts supplier "fouled up" so only one bearing was correct, the large one & seal were not
So try again this morning, pics to follow
Disc conversion on a Sterling 10.25, Russ? And I'm not looking forward to those temperatures this summer. Here in Las Vegas, its miserably hot from May- October
