ISPKI
Finally, I have all the parts to complete my zf5 swap. I have a 94 f250 4x4 with a n/a 7.3 and e4od. The ZF5 that I am putting in is out of an early 90s f super duty 2wd with a 460 gasser. I will be using my buddy's gigantic magnet drill to machine the holes on the ZF5 bellhousing.
Todays progress:
Transfer case and drive shafts removed
Linkages, wiring harness removed
Crossmember bolts removed
Transmission bolts removed
All but 1 starter bolt removed
Interior and inspection plate removed
I need to get the starter off, crossmember out and fill tube out before i can drop the e4od
Todays progress:
