FORDF250HDXLT
outdated tech article found here:
http://www.oilburners.net/forums/showthread.php?t=4134
setting to the values found here in this updated version will yield MUCH improvement than the values in the old article.so much so,you'll think you swapped in a fresh trans.
A/T - E40D FIPL Sensor Trouble Shooting & Adjustment
TECHNICAL BULLETIN # 186A
TRANSMISSION: E4OD
SUBJECT: FIPL troubleshooting & adjustment procedures
APPLICATION: Ford
DATE: Jan 1994
E4OD
FIPL Trouble Shooting & Adjustment Procedures (Diesel Applications Only)
Poor transmission performance and/or premature transmission failure may be caused by a defective Fuel Injection Pump Lever (FIPL) sensor, or sensor signal. The sensor is located on the Fuel Injection Pump (Figure 1) and is used to inform the Transmission Control Unit Assembly (computer) of throttle position.
Ford Motor Company recommends that the FIPL be checked or replaced every 50,000 miles. However, it is possible for a FIPL sensor to fail at less than 50,000 miles. Therefore, it is highly recommended that you install a new "upgraded" FIPL sensor when a transmission overhaul is performed on any diesel applications.
You should also be aware that early design FIPL sensors are not as desirable as late design sensors.
Another potential concern is that the wiring harness leading to the FIPL sensor may be broken or shorted to ground. Closely inspect the harness where it is routed across the top of the engine to the FIPL sensor. The natural vibration of a diesel engine can easily wear through the wiring insulation where it contacts the engine, brackets, etc.
Note The voltage specification for signal return (item 2, page 2) was incorrect on the original bulletin. Remove original # 186 from your files and replace it with this revised bulletin. # 186A.
Note For testing and adjustment information see following information.
TESTING THE FIPL SENSOR
Note During these tests the negative lead of the voltmeter MUST be connected directly to the negative battery post and the computer and FIPL harnesses must not be disconnected.
1. Wire A is reference voltage sent to the sensor from the computer ORANGE/WHITE
TEST: With the KEY ON, ENGINE OFF voltage should be approximately 5 volts.
2. Wire B is the ground path from the FIPL sensor to the computer BLACK/WHITE
TEST: With the KEY ON, ENGINE OFF voltage should be volts?? or less.
3. Wire C is the throttle opening signal sent to the computer from the FIPL sensor . TEST With the KEY ON, ENGINE OFF and the throttle at idle position, voltage should be approximately 1.2 volts. With The throttle fully open, voltage should be approximately 4.5 volts. ORANGE/WHITE (CENTER WIRE)
The sweep from 1.2 volts at idle to approximately 4.5 volts at full throttle should be smooth. A meter with a snapshot or min/max capture mode is useful to catch intermittent "opens".
If the previously described range cannot be attained, FIPL adjustment can be achieved by rotating the sensor (on its bracket) one way or the other until the voltage values are satisfactory.
DIESEL FIPL SENSOR INFO
DATE 1992
REASON
Early Black FIPL has High Failure Rate
RECOMMENDATION
Always replace the black colored early FIPL or any colored FIPL having 60 thousand or more miles with the late gray colored FIPL.
PART NUMBER
F2TZ-9B989-C
end of article.
couple more things that are not included here that you need to know:
engine should be warmed up first (or i guess as long as the fast idle isn't set is all) and normal warm idle must be set to 650-700 RPM.
T-15 is the size for the small bolts.T27 for the large mounting bracket bolts.
oh,as far as test #2 there.the reason why the voltage is blank (??) is because there is non there,being that it's the ground wire of course.if you suspect a faulty ground,then you would check it for resistance i should think.
when asking for the part at an auto store,don't ask for a FIPL (fuel injection pump lever) you'll just get the deer in the headlight stare.
tell them you need a TPS (throttle positioning sensor) and their computers will find the correct part for you.
more info;
don't be concerned with the color of the FIPL/TPS you find in the stores today.if your sold one that has black plastic,this does not mean it meets the specs of the failure prone ones of yesteryear.
TRANSMISSION: E4OD
APPLICATION: Ford
DATE: Jan 1994
E4OD
DATE 1992
REASON
RECOMMENDATION
PART NUMBER
F2TZ-9B989-C
end of article.
more info;
