Yet another water seperator alternative
Status
Not open for further replies.
AZBLACKSMOKE
no truck payment
Safford,Arizona
Hey guys. Just wanted to share what I did last night to my truck.
Since I got it, I have been having serious air in fuel problems. The dreaded start and die, and the "all of a sudden my truck runs like a bat out of hell" for a second or two symptoms. A few weeks ago, I replaced my return lines and it was better, but I was still getting air somewhere.
I read the water seperator exposed article and decided to take a closer look at mine. I removed it from the truck and upon the first visual inspection I could see no wet spots or leaks, so I decided to grab my vacuum gun and test it to see if it would hold vacuum. It did not. It would quickly bleed off. So, I did the only thing I could do and replace the o-ring on top. It still bled off. So, I decided to look for a replacement.
Not wanting to put another used water seperator in, I went to my local Carquest and came up with a solution. So far I am pretty happy with it. Ive only been able to test it once this morning, but from the way it runs, and the fact that I had NO air in fuel symptoms...I am confident I fixed it.
The new water seperator base part# is 89309 and cost $25.22. The element which is part# 86123 was $9.82. I then had to go to Home depot for two brass fitting elbows. 1/2 x 3/8 nipple. They cost me $10.82.
The holes on the new base where 5/16 and needed to be enlarged a little bit with a 3/8 drill bit, and after that, I was able to bolt it up in the original water seperators spot. I did have to move the cruise control servo out of the way temporarily. There is plenty of room to R&R the filter as well as to reach the water drain on the bottom of the element. Only draw back, is no WIF light provision. Which, IMHO, is a small drawback for increased filtering and a trouble free design.
I also replaced the fuel line from the water seperator down to the metal lines near the frame, just to be on the safe side.
Sorry for the crap cell phone pics.
papastruck
WA
Nice. I'm doing something similar on mine, using Wix parts, but they look the same. I think they were originally for the 6.2. I was going to put mine back upstream of the electric pump, but it just hangs down too far. I've grabbed a Spectre filter to handle the chunks back there, and I think I'll put the separator on the firewall like this.
87crewdually
Southern Nj.
Good find. Here's some info for the Napa crowd like myself.
NAPA CROSS
Filter:
3123
Element Dimensions
Height O.D. I.D.
6.629 3.698 1-12
Gasket Dimensions
Number O.D. I.D. Thickness
Attached 3.444 3.100 0.260
Principal Application
Chevrolet & GMC Trucks 6.2L Diesel Eng.
(82-83); Fuel/Water Separator w/Drain (12 Micron)
Interchanges
AC DELCO......................... 12944
T944
APOLLO.........................LFP944F
BALDWIN...........................BF781
BIG A FILTER.................... 95123
CAM2 .............................LFP944F
CAR CARE PARTS .........DF3710
CARQUEST ....................... 86123
CATERPILLAR ................. 3I1222
CHAMP (ALSO SEE
LUBER-FINER)............LFP944F
CHAMPION AUTOMOTIVE GF45
CITGO ............................LFP944F
CROSLAND......................... 5009
DEUTSCH..........................FF765
DONALDSON ............FFP550944
P550944
FLEETGUARD.................FF5034
FLEETRITE................. FFR85034
FRAM.................................P3710
G.K. INDUSTRIES .............TP944
GENERAL MOTORS... 25011233
25011285
GLOBAL FILTERS ............ 40781
HASTINGS............................. 844
FF844
KRALINATOR...................... F155
LEE...............................LFP9944F
LUBER-FINER (ALSO SEE
CHAMP) .......................LFP944F
MICRON............................. F6266
MIGHTY..........................LFP944F
MIGHTY................................ T944
MOTORCRAFT..................FD822
PROMATCH.....................9Y4422
PUROLATOR................... F60266
PER266F
QUAKER STATE............ QS3710
WARNER .......................LFP944F
WIX..................................... 33123
WOODGATE................WGF5034
Base:
4309
Element Dimensions
Height O.D. I.D.
B-0
Base for Fuel/Water Separators 3123, 3418
(1/2-NPT)
Interchanges
BIG A FILTER.................... 96309
CARQUEST ....................... 89309
WIX..................................... 24309
This qualifies as an instant Tech Article. Good job!
Status
