6 Nebraska IDIs
- Joined
- May 27, 2007
- Posts
- 4,247
- Reaction score
- 15
This is a brand new yoke for the front driveshaft of an F350 with a BW1356 transfer case. Spicer part # 2-4-5442
This yoke is NEEDED if you are converting an F250 to a D60, or even just converting an F250 front drive shaft to the D60 double cardian joint drive shaft.
It turned out to be the wrong yoke for my "rare" 1356 transfer case, since my case has a 31 spline shaft instead of the normal 32 spline shaft.
The end of the splines show signs of me trying to install it. But they are fine and it slips right on to the correct 32 spline 1356 case. I know because I tried it tonight just to make sure. The shop won't take it back since I already installed the dust shield and the splines showed signs of attempting to install it.
I have $121 in it including tax and freight. Someone give me $100 for it. I'll take a $21 loss for the signs of the install attempt.
I can get pics if you want.
