Compatability of ZF Gas 460 trans with IDI
Status
Not open for further replies.
Goofyexponent
Mentally Unstable..
Halifax / Nova Scotia
I found a ZF5 from a 460. Will it bolt to my 7.3 directly? Do I need to drill the bellhousing to make it fit? Is it out of the question all together?
Cincinnati Guy
Cincinnati, Ohio
I have been told it is not a direct fit. I been told it wont work then been told you had to drill out the holes. Anyways the gear ratio of the transmission would be different than one out of a diesel.
BigRigTech
Diesel junky
Nova Scotia, Canada
I've been told both ways, I had one guy tell me he took the ZF from his 460 powered wrecker and put it in his IDI powered wrecker...This was about 2 months ago via a phone conversation....I've also heard you need to drill holes....:dunno....I told him that and he said it bolted right up.:rolleyes:
91f2504x4
KY
There is a picture somewhere of a BBF ZF with the rear plate from a diesel (or vice versa) engine laid over the front of it and it is very close but not a direct fit, if I remember right there are 2 holes different. I will look to see if I can found that picture, but if not I am sure someone will post it soon.
FordGuy100
Silverton, OR
I'm pretty sure Russ did it, said that the top two holes had to be drilled out a little bit to work. At least I thought it was Russ....
FordGuy100
Silverton, OR
And if it is Russ's truck...the gear ratio's werent bad at all. Shifted nice and seemed to have good spreads between the gears ;Sweet.
Its been going on 2 years now since I've ridden in it though LOL
typ4
Newberg,OR
The final answer is, 4 holes and 2 dowels are different, the top ones will work.
I bolted a 460 to my diesel zf. After drilling.
blue original idi holes
pink idi dowels
green 460 bolts
brown 460 dowels
red 460 starter.
oh and someone needs to move this to the tech section if it is worthy.
hesutton
The Anti-Anderson
Bowling Green, KY
Thanks for posting that Russ. I'm planning on trying to put the ZF5 I have from my F350 gasser parts truck on the crew cab IDI.
Heath
Status
Oiler
