6.9 longblock (complete)
complete longblock. unknown vintage. no pump and lines included. from the intake to the exhaust and from the water pump to the trans adapter plate is there too. the fuel pump eccentric committed suicide and sent shavings into the oiling system. the crank is scored as a result. come and get it. in two weeks I will strip it down and junk out the block and heads.
tractorman86
Buckeye, AZ
cool, who do you use to ship, can it be setup COD or should i send you $ via paypal? i'm looking to drill and tap for a pyro. and have them HI-Temp ceramic coated for the turbo i am putting together. thanks a lot calvin!
Mat J
Way down south
Jupiter, FL
does the 6.9 use the same tach pickup as the 7.3 because mine is going out and could use one if you have one.
EDIT sorry didnt see how old it was and mel linked the damn page :)
