1994 Ford Cummins conversion
ncovey
Diesel Poor
Missouri
I showed some pictures in the "You put a what in what thread", of my conversion. Not meaning to hi-jack that thread I am moving stuff over here and going to continue posting my progress, hope you all enjoy-Nicholas
ncovey
Diesel Poor
Missouri
Some of the details are- '96 Cummins 12 valve, Dana 80 from '97 ram 3500, Nv4500 5-spd, Ford Dana 60 converted to factory style dual wheel, '96 241DHD transfer case.
ncovey
Diesel Poor
Missouri
Mount for the S400 (I know it is not supported just watch)
Alternator mount-
Air Conditioner /Tensioner/coolant outlet combination mount-
Serpentine Belt installed-
Radiator mocked up getting ready to mock up the intercooler-
View from passenger side fender well-
GoodB0Y
new west/b.c.
looks real nice nicholas... are those factory mounts bolted to the block with fabricated ones on the x-member?
ncovey
Diesel Poor
Missouri
Yes, they are. One is a factory 12 valve mount, and the other is a factory 24 valve mount.
GoodB0Y
new west/b.c.
I've been doing allot of research on motor mounts and your seem really slick... are you happy with them? anything you'd change?
and can I ask what side is the mount from the 24v?
ncovey
Diesel Poor
Missouri
So far I like the design, but mine isn't on the road yet. Soon I hope. Passenger side is the 24 Valve.
ncovey
Diesel Poor
Missouri
I finally got some more work done. I finished and installed the wastegate, merge collector/hot pipe, and installed the secondary. Installed the DDP 4's, and the 3k Gov springs. Stripped apart the front wire loom and relocated the starter relay to the drivers side. Had the oil feed lines made and installed them. I am now working on the oil return tubes, and the cold piping.
FordGuy100
Silverton, OR
Looking good man ;Sweet.
That turbo is massive :eek:, will turbo lag be bad with that thing? Whoops just looked at the pics a little closer, sequential turbo setup it looks like ;Sweet
ncovey
Diesel Poor
Missouri
Got some more stuff done and installed. Painted the compressors, and made up the cold piping and installed it-
razorback
branson, mo
wow thats a clean truck, nice project. i want to do the same (i have an 87 f350 CC) but have too many other projects going right now.
which part of missouri are you in?
crispy74
