Check it out...
You can see the crack running for several inches along the lip, but what the arrow is pointing to is daylight you can see through the crack! I'm going to go ahead and assume that is bad. There is a similar crack on the other side. FYI, I used a rubber mallet to separate the manifolds.
Also, there is some pitting at the gasket face area that is of concern.
The ***** is I had the body all nice and shiny before I found the cracks.
