Drive Shaft info please
Kizer
Denton, Texas
The truck that I'm working on is a Diesel (of course!) '90 F350 CCLB RWD, soon to have ZF5
I need the drive shaft assembly or part numbers, my parts catalog only covers slant nose.
I'm looking for a ZF547 too, by the way (both posted in "wanted".
Thank you,
Kizer
Kizer
Denton, Texas
An 85 up Slantnose with T19 uses E5TZ 4R602-E, I believe.
Any chance it's a similar part # for brick nose?
Kizer
Denton, Texas
I guess this is a tough one to answer...at least I don't feel too bad, anymore, for not being successful in my research.
I'll post the part # in parts bin when I get it figured out.
Kizer
Denton, Texas
The 90 came with ZF right?
I just need the oe parts, I think.
Yeah, started in 88 or late 87.
Thing is, you seem to be trying to find a "new" one. That probably won't happen.
Either have one built, or get one from a junkyard.
Kizer
Denton, Texas
Oh no... I don't need a new one. I just like to have the part # when I'm looking for parts. In my experience, it mitigates the the opportunity for failure due to "misunderstanding". That's all. I hate making more trips to the parts house / junk yard than I absolutely have to.
Kizer
Denton, Texas
$275 at the junk yard!
Jeez man the whole truck wasn't much more than that.
Still no part #
dunk
Dunce
NJ
Amazed you found a yard with a straight undamaged shaft. Around here everything is forked so things like drive shafts are always destroyed. I paid around $700 for a new two piece shaft years ago with all spicer parts and joints, if that helps.
subway
be nice to the admin :D
York PA
If you are handy you can build your own shaft and have it balanced for far less. Local yards only ask 35 for a drive shaft. The trouble is like mentioned most get bent moving the trucks.
Kizer
Denton, Texas
Found 1 on fleabay for $175! They had pics of the truck so, as long as the DS actually came out of that truck, should be good... At least I'll have a better starting point.
freqencyheight
